Gaiter's 06 VZ SS Thunder
Discussion in 'VY - VZ - WK - WL - V2' started by Gaiter, Sep 13, 2015.
Tags:
  1. Gaiter
    Gaiter Active Member
    VZ SS Thunder
    Update, not much of one. Cash is still in savings mode so no $$$ for the poor ute.
    Taillight stopped working, or worked intermittently so thought I would get into it this morning and see what's what. Was expecting it to be a painful job with the tub liner, surprisingly only like a 5 minute job to get the whole taillight out let alone just changing a bulb.
    Took some pictures in case anyone wanted a run down of how to change the taillight in a VY/VZ ute with a tub liner:
    1. Undo these two screws
    2. Lift the liner in the middle of the tray to get the liner out from under the lip
    [​IMG] [​IMG] [​IMG]
    3. Pull back the liner to expose the panel hiding the taillight wires
    4. Undo the screws around the panel (both sides of mine are missing some screws seems someone might have changed bulbs before and lost the screws?)
    [​IMG] [​IMG]
    5. Unscrew the bulb holder from the light to expose the bulb and replace
    All up I undid 9 screws, there should be 10
    I also found surface rust!!! Argh, so I gave that a bit of a rub to get rid of it with a cloth and some WD-40
    Trayner likes this.
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Those tub liners are the worst. Much better to get the rhino lining type stuff. All the factory ones do is trap moisture.
    Gaiter likes this.
  3. Trayner
    yeah I ether need to replace mine or get like wraith said ,mines got old stains and **** all over it makes it look old and crusty
  4. Gaiter
    VZ SS Thunder
    Was honestly surpised by how much there was, just little easy to remove spots. But you could imagine after awhile it starting to take hold. Is a 10 year old ute but still. Possibly another thing to add to the damn list lol
  5. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    I'm going to pretend I didn't see the above and not add anything else to my list.
    Mind you, taking out the complete tub liner is the main reason I haven't done a reverse camera haha!
    I feel with how old they are the damage would already be done.
    Gaiter likes this.
  6. thatotherguy94
    thatotherguy94 Member
    adelaide
    VS Acclaim, VS II Calais, HQ Premier
    Might have to add that to my list, I had a look down the side of mine today and noticed its quite dusty under there..
    Nice looking ute
    Gaiter likes this.
