Front end noise (still)
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Clubsport5972, Nov 23, 2019.
  1. Clubsport5972
    Clubsport5972 Member
    Timaru, New Zealand
    VE Commodore Omega 3.6l
    I’ve replaced the tie rod ends, caster arms, lower control rods, and sway bar bushes. Still getting a knock and clank from the front every now and then. Anyone any idea? More apparent when reversing and on full lock either left or right. Feels like the wheels are fighting against the steering and jumping a little sideways. Totally out of ideas now. Anyone had anything similar? It’s an 08 Omega btw.
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    Have a look at your engine mounts, strut top bushes and the 6 bolts that hold the front end to the chassis. Those front end bolts need to be super tight or you will get clunks going over bumps.
    syked likes this.
  3. syked
    syked Donating Member
    2011 WM Caprice
    Also check:
    - Steering rack for play and the actual mounts on the rack
    - Sway bay link pins
    - inner rack ends .
    Fu Manchu likes this.
  4. Slick_Vp_23
    Slick_Vp_23 New Member
    Gympie
    VE MY10 SSV M6
    Hey mate, maybe ball joints if you haven’t replaced them with the lower control arms? +1 for sway bar link pins and struts/strut tops. Good luck
