Ford Mustang scores appalling 2 star Ancap rating
Discussion in 'News/Updates' started by zero_tolerance, Jan 26, 2017.
  1. convas
    convas Member
    Corvette z51 C4
    In my younger days I had a VH SLE 5 litre trimatic on nitrous and gave that car hell, as you do when you are in your 20's and had no diff or axle problems ever, only thing I busted was harmonic balancer spun off its collar and a couple of push rods went through their rocker arms, all factory stock stuff, except for the nitrous.
  2. immortality
    Sth Auck, NZ
    Clearly not. Fords iconic Pony car is built to a price point with pathetic 3 link semi-trailing rear suspension that is worse than the semi-trailing rear suspension fitted to every commodore since for ever..........
  3. Towcar
    Towcar Well-Known Member
    Auckland NZ
    VX Berlina Wagon
    Each video showed the driver loosing it is the same way as the car snapped back at relatively low speeds, there is a fundamental handling flaw right there. My 16 year old commodore station wagon behaves better with similar power.
    immortality and zero_tolerance like this.
  4. immortality
    Sth Auck, NZ
    Yep. I did something similar in my old VH but it was on gravel....
    Once it was obvious the ass wasn't going to pull back in, in time, I simply turned the wheel the other way and did a full loop instead :D
    I think the issue is the single top trailing arm mounted in the center, our cars have 2 and were more likely to axle tramp when the top trailing arm bushes were stuffed.
    VS_Pete likes this.
  5. c2105026
    c2105026 Active Member
    NSW
    2000 VTII Commodore Olympic, 2012 Ford Focus ST
    Re: ANCAP - two things.
    1 - the system has a degree of corruption built into it. I have personally seen this. The RTA conducts (or at least it did) ANCAP at its Huntingwood crashlab. In 2005 I witnessed a test as an RTA graduate engineer and the car, a popular SUV, failed - bad. Manufacturer reps were there to convince RTA to run the test again, as a 'mulligan'. Car then got 4 stars, quite good for back then.
    2 - I would not be surprised if cars were being designed just to get good marks in the test. Frontal impact and side impact are but two ways a car can crash. There is roll over, sideswipes, rear-end shunts. A car may perform in an ANCAP test beautifully, getting full marks, but in a modest 45 degree impact coupled with a rolling spin completely fail.
    I don't buy according to ANCAP, I just do my best not to crash instead.
  6. Bob Watson
    Bob Watson New Member
    Kybong
    2009 Ve Berlina
    Look as far as I am concerned people still associate Mustang with Steve McQueen in Bullitt. Now remember this is back in the days when all cars were made of steel ( Australian cars too ). Now both Holden and Ford Heads are being given a choice between one car that looks like a Mazda with 400 gears and a Mustang GT etc. I wonder how long people will have to go before they have to replace their cars, because they can't handle Australian conditions. The head people at both Holden and Ford tell us they have extensivly tested their vehicles in Australian conditions. What about out in the bush when you can hit a pothole in the road and take a week to get out of it. Mustange has been having troubles since the 70's and they even dropped out a 4 cylinder version which sounded like a nail in a fruit tin. Not only the History has gone from Holden, but the soul also. Thank god I have a real Holden.
    commodore665 likes this.
