Engine replacement/rebuild. Need help.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by NZsmoka, Feb 6, 2015.
  1. NZsmoka
    NZsmoka New Member
    Palmerston north, new zealand
    1996 VS Commodore Executive
    My 3.8 ecotec spun a bearing the other day on start up. And i am unsure if i want to rebuild this current engine or just buy a 2nd hand one. Or even to buy another type of engine all together.
    Im wondering what the cheapest option is, as i do want much more power out of my engine. And if i was to do a rebuild, are the Buick 3.8's expensive to work (E.g ACL race bearings, titanium valves..)
    And would it be better to buy an already supercharged engine over a a non-supercharged that i will supercharge myself.
  2. VPRob
    VPRob Active Member
    nowra, NSW
    VP executive sedan V6
    As a general rule simply buying a 2nd hand motor is going to be far cheaper in terms of keeping your car on the road. I bought a used VR motor for my VP for $125 privately and it is still running happily some years and kilometres later. But I know NOTHING about performance mods or supercharging so can give you no advice about that at all..........
  3. sleepa
    sleepa Shiny...
    2010 VE SS Sportwagon, Audi A4, Combo work hack
    I would assume a supercharged engine would be cheaper then supercharging a normal engine. Of course you still need the ecu, etc.
    Might be a good step up from the ecotec.
    Or you could find a V8, just a little more effort.
    Most expensive would probably be to rebuild your engine.
  4. immortality
    immortality No more smoky bacon :( Staff Member
    Sth Auck, NZ
    Unfortunately here in NZ people seem to want a premium for a 2nd had L67 engine.
    Might be best to just get another ecotec engine and then at least you're back on the road again.
  5. ephect
    ephect Donating Member
    VS Acclaim V6
    Cheapest is to get a second hand donk and drop that in. No reason why U can't then do a little research into good performance mods/parts and rebuild ur original donk. It'll allow U to get back on the road quicker and U can go as sedate or as mental as U want with ur original and drop that in when ready.
