Drive Pulley squeal
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by legend1944, May 10, 2017.
  1. legend1944
    legend1944 New Member
    canberra
    series 2 VS Calais V6
    My VS 3.8l has loud rev dependent squeal from one of the pulleys. sound seems to be coming from either steering pump or tensioner pulley. With belt removed i cant feel a problem with any of the pulleys ( no stiffness to turn or undue play). Any suggestions for isolating the problem?
  2. VS 5.0
    Try spraying some CRC/WD40 on one pulley (not where the belt runs) and then run the car.
    If the sound disappears you have found the culprit.
    If the sound is still there, repeat one by one until you find it.
    VS_Pete likes this.
  3. VS_Pete
    X2
  4. spud_22
    spud_22 Member
    VFII SS-V Wagon, VS UTE, 96 VS Senator
    Put a socket on the tensioner and push it down, if you stand to the side of your car watch and see if the tensioner moves moves perfectly up and down. Iv had one that that pulled down on an angle and caused the belt to squeak over the pulley.
  5. legend1944
    canberra
    Thanks for the advice. Did as you suggested. Started with tension pulley and squeal vanished
    VS_Pete and VS 5.0 like this.
  6. VS 5.0
    Obviously if the sound returns you will need to replace it.
    VS_Pete likes this.
  7. VS_Pete
    X2.........................................................
  8. Hooblah
    Hooblah New Member
    Rockhmapton
    VS Berlina
    Putting a new pulley on the tensioner is not hard, just remember to take it off the thread is reversed.
  9. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    Depending on when you last changed your drive belt and tensioner, it might be worth just replacing them both - it's cheap insurance.
    Repco regularly does 15-20% off Gates drive belts and tensioners
