DIY: ECU Scantools/Data Cables
Discussion in 'Electrical Wiring / Questions' started by michaelw, Nov 6, 2005.
  1. br14nh
    br14nh Back in the saddle....
    SW Sydney
    VX V6 wagon 5sp Manual
    Hmmm, thanks for the info - I get the beep & the usual warning lights flashing, as described in the "readme"'s.... but I can't even get those gauges working - nothing on my EFI Dashboard responds, only a few of the the raw data & graphs, & I don't think there is one for engine timing... may be because I have a VX? I guess I'll have to wait & see what other feedback there is....
  2. michaelw
    michaelw Donating Member
    Newcastle NSW
    VX S2
    So it displays data for a bit then shuts off? The logging on the trial version of the software is limited to about 20 seconds. But you should be able to get live data. When you select the engine data macro and then go aldl->start what does the tab for the dashboard display?
    The vx does not have too much data on it at the moment. but you should get some sings of life. If you have no joy I will sort something out.
    Mike
  3. michaelw
    Newcastle NSW
    VX S2
    As the trial version is limited, you cannot display many graphs at once BUT you can change what is displayed. Right click on an active graph and then follow the menu to get what you want to read.
    Mike
  4. VRV6BT1
    VRV6BT1 New Member
    telarah
    S1 VR V6 BT1
    G'day.
    Just wondering if I supply the 16 pin plug and any other needed supplies coukd you make a aldl to usb cabke for me, I used to be ablr to do this kind of stuff myself, but my nerves are shot and I shake too much to solder now.
    I am looking to run a linux backend off an old lappy to run gps, mp3, and diags, and maybe sum old skool games :D
  5. Nevyn
    Nevyn Member
    Latrobe Valley
    VN Sedan
    Hi...I'm having trouble getting the codes with the engine light. I inserted the paper clip into pins A & B in the diagnostic plug, turn the key to on (all the right things light up), the engine (thermo) fan comes on, but the engine light doesn't come on, so there is no flashing codes. Is this a common problem?...could it be something wrong with the ECU? I thought if there was a problem with the ECU I'd get a 55 code, but its hard to get that when the engine light dosn't come on. With the paper clip out, the engine light will come on when car is first started, but goes out with the battery & oil lights once the engine fires. Any and all help needed and appreciated.
  6. Phreddy
    Phreddy Bye SV6 - still love you
    W-Sydney NSW
    VS-II Statey-8
    A question about the Jaycar plugs....
    I've noticed that internally there is a link between pins 4 and 5. I've had a look at the connector in my VZ and it looks that both pins 4 and 5 are used.
    Question is - if I plug this Jaycar plug into the socket I'll be shorting these pins together in the harness. Is this going to blow something up? Or is this connection necessary to establish comms??
    Any help much appreciated. Thanx! :thumbsup:
  7. ren11000
    ren11000 New Member
    VY SS UTE A4
    pins 4 and 5 are earth wires
      File size:
      75.7 KB
      3,315
  8. jet-6
    jet-6 Yer im that guy!
    East Gippsland, VIC
    MY06 VZ SX6 ADVENTRA
    Can you make your own scan tool for a VZ with a Alloytech?
    Id love to own one so i can see the codes/faults
    EDIT, i have seen complete handheld units on ebay, do they work?
  9. jet-6
    East Gippsland, VIC
    Bump this thread up, ive been looking into a complete scan tool, these are the two that impress me the most:
    U581 CAN Trouble Code Reader OBDII/EOBDII Memo Scanner - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 28-Jan-09 10:45:00 AEDST)
    and
    eBay Motors: OBDII EOBD Scanner Tool CAN-BUS OBD2 Reader GS500 (item 260350550151 end time Jan-24-09 13:02:22 PST)
    What do you guys think, or am i better off using a lead and my laptop(has to be USB)
    Unless you can do more stuff with the laptop id rather have the handheld unit
    So any ideas would be great right about now
  10. michaelw
    Newcastle NSW
    VX S2
    I have not had the time to look into CAN OBD yet. There are DIY units but I haven't built one yet. I suspect that the CAN handheld will work but it would be a guess. The Alloytech runs OBD CAN so the ALDL and OBD VPW described here won't work.
    Mike
  11. bcjohno
    bcjohno New Member
    VT exec gen3
    whats the best software and can i use the vn lead with a different plug to run a vr?
  12. kyled2012
    kyled2012 I.T. Technician
    Western Suburbs, Melbourne, Victoria
    VZ Calais 3.6
    Hi guys, sorry to bump a very old dead thread,
    Is anyone on the forums still selling the ALDL to USB or Serial cables for VT?
    I have all the components to make one, I just want something more neat and professional.
    If not, I was going to buy this ALDL -> USB adaptor. has anyone previously had any issues with this product or seller?
    Cheers guys :thumbsup:
  13. typicalaussiebloke
    typicalaussiebloke New Member
    Unanderra
    Commodore VT II Executive station wagon
    I too am gonna add to this old thread, though my story is different.
    My brother wanted me to build an ALDL cable so he can diagnose my VT Commodore and so I have built the given circuit in this thread that involves the ATMEGA8 chip and MAX232 chip, but there are some grey areas with that circuit. Firstly and most importantly, what is the frequency of the crystal that connects between pins 7 and 8 on the ATMEGA8 chip??? And is the frequency value of the crystal universal for all Commodores or does it vary for different models? I have also gotten the OBDII plug as well but am unsure of the pin connections, does anyone know which connects to what pin?
    If anyone who has built the ATMEGA8 version of the circuit can help me I would most appreciate it.
    Troy
  14. j_ds_au
    j_ds_au New Member
    VS T4
    It's a bit late for an answer, but at least I can help regarding the pinning : 4/5 is ground, 9 is data.
    But OTOH, that info's easy to find, so I wonder how much (if any) effort you put into this ... ?
    Joe.
