DIY: ECU Scantools/Data Cables
Discussion in 'Electrical Wiring / Questions' started by michaelw, Nov 6, 2005.
  1. brettless
    brettless Guest
    I believe the unit has the new elm327 chip.the laptop was under its own power at time of testing and no inverter was used.The unit did however work on a 2004 ford
  2. michaelw
    michaelw Donating Member
    Newcastle NSW
    VX S2
    As you have already got one of theirs, i would try and get it replaced for one based on the elm322. I am surprised that the 327 does not work for the genIII as acording to the data sheets it *should* but I haven't played around with that chip yet.
    Mike
  3. HDT_aero
    HDT_aero Banned
    SA
    manual VN aero
    just so you know guys 1/2 watt 10k resistors work fine aswell and are easier to come across
  4. brettless
    brettless Guest
    Hi , I have sent a few emails of to the supplier to get more info but there seems to be a lot of conflicting information im getting.I have a manual for the vehicle i have and it does suggest 2000 and on models are obd2 compliant and i have sent that extract to them.Shall see how i go now.
  5. brettless
    brettless Guest
    Hi there, I got that Elm 327 chip to communicate with my car 2 day.I retired it on a ford 2004 and was able to get sensor data,then tried it on a Avantra 2004 5.7litre and it seemed to have a bit of a hiccup then bingo got sensor data out of it.So i tried it again on my Vx 5.7 litre and bingo i could get sensor data,very strange but thing somehow scanning the Avantra jolted it into action,maybe the elm Gm protcol sensing a bit dicky,will see how it goes
  6. michaelw
    Newcastle NSW
    VX S2
    Try this. send AT SP0 to the cable through hyperterminal or your scan software. This will tell it to try ALL protocols when it has trouble. The chip has a 'feature' to remember the last protocol it used and if you are swapping it around it could get annoying.
    For more info check page 11 of the data sheet.
    http://www.elmelectronics.com/DSheets/ELM327DS.pdf
    Mike
  7. Chev_SS
    Chev_SS Guest
    Does anyone know where i can purchase an interface cable for a series II VY commodore SS.
    I have downloaded the trial version of EFILIVE but i need the cable.
    Thanks
  8. michaelw
    Newcastle NSW
    VX S2
    I have made an addition for those who have a GENIII and can program microcontrollers.
    Mike
  9. michaelw
    Newcastle NSW
    VX S2
    News just in. EFILIVE has definition files for VX and VY V6's
    Mike
  10. OZ38
    OZ38 Member
    Jurien Bay WA
    VS V6 T5 & VY V6 M35 UTE
    This sounds like good news, but can you tell us what It means for us now ?
    Deek
  11. Chris76
    Chris76 New Member
    Hi Guys,
    Can anyone provide a copy of the standard bin files/maps for the VS ECOTEC amnual as Im conveting to manual form auto. Please PM me if you can help
  12. michaelw
    Newcastle NSW
    VX S2
    You can see what efilive can do before you make/buy a cable, dowload efilive (the version on the server comes with the VX/VY V6 files) and after it is set you go to file->select vechicle and load the file. Some VX's may have a problem with the supplied file (see attached for a corrected file).
    Mike
  13. Mike:)
    Mike:) New Member
    VX II
    Here it is....
    Ok I have done the work for you :) Here is all the info you need to make your very own ALDL link. I have done it, and it works on my VX II commodore.
    Attatched are the schematic, part layout, and PDF for making a PCB for your link.
    There are three options for powering this circuit
    Option 1 on the car side use Ground Data and 12v // on the PC side use pins 2, 3, and 5
    Option 2 ointhe car side use ground and Data/// use a 9V battery on the power in pins /// use pins 2,3,and 5 on the PC side.
    Here is a link to download an ALDL tester to test youe citcuit BEFORE you hook it up to your car!!!
    http://www.ttspowersystems.com/software/dm350/ALDL_TEST/setup-ALDL.exe
    Here is a link to the circuit that I used.. It seems to be the best.
    http://students.fct.unl.pt/users/lat12089/dsm_link_cable.htm
    Note you have to conect pins 1,4,6 and 7,8 at the serial port plug.
    Here is a link to the serial plug pinout:
    http://www.cisco.com/univercd/cc/td/doc/product/dsl_prod/6700/iad1101/cable.htm
    You have a DB 9 on the back of you PC.
    I used EFIlive 4:
    http://68.178.219.18/software/EFILiveV465_305_Eval.exe
    Have fun
    Mike
    View attachment aldlfinal3.zip
    View attachment aldlfinal3_brd.pdf
  14. michaelw
    Newcastle NSW
    VX S2
    If you join the DTR and RTS lines together to power your circuit you run the risk of cooking your serial port. Route the power through a diode for each line. (see circuit on first post).
    If you want to power it off the car (no real need unless you have a cheap laptop, cheap usb/serial converter or want to use a pda) you can source 12V from pin 16 on the obd plug. No need for a 9V batery, the battery/cig lighter power option is needed on US cars that have a different OBD I plug.
    Mike
  15. Mike:)
    Mike:) New Member
    VX II
    Hi there,
    Yes there are diodes to protect DTR and RTS. I am using the same basic circuit as you. :)
    Just have a few power options. - it works from a pda which is cool!
    There is a PDF to make a pcb from. Thought it might help a few people.
    Mike
  16. michaelw
    Newcastle NSW
    VX S2
    Added some info about the airbag flashing when you use an adaptor on the VX (and the VY I guess)
    Mike
  17. JcB
    JcB New Member
    Pukekohe - New Zealand
    VS Calais Series II
    Hello Mike, i'm still debating on buying an ALDL cable for my VS from you. I'm looking at the above diagram, it's different from the www.techedge.com.au one. Could you tell me what models this would work for. Many thanks.
  18. 14secvp
    14secvp New Member
    south island newzealand
    vp v6 commodore executive
    easy interface 5volt ttl
    just been reading what the honda boys have been doing with a nokia cellphone data cable (come as serial or usb) using it for logging seems to have a max 232 chip in it.looks like the same circuit as some of the max 232 interfaces costs about 25 bucks just cut off the cellphone plug on the end bare the wires and viola .maybe i might of been missing something but have a look schematics for the cable on the net nokia dku 5 or nokia dku 2 or check out www.pgmfi.org let us know what u find out sure beats making one:thumbsup:
    heres the schematics they are a bit different but with some modifications might work
  19. michaelw
    Newcastle NSW
    VX S2
    It will work for VR/VS/VTS1 V6 and V8, and then VT SII/VX/VY V6's only. (and whatever the matching stateman's and utes are)
    The techedge circuit does not seem to work the VS V8 onwards, I haven't put too much effort in working out where the circuit won't work as the two transistor method seems to work with everything. I use the above circut with obvious modifications for the usb one I sell and have not had any compatibility problems. I originally sold a version based on the tech edge circuit and had troubles.
    But if you are handy with an iron my circuit shouldn't pose any problems.
    Mike
  20. JcB
    JcB New Member
    VS Calais Series II
    Great! Thanks.
    I'm a learner with the soldering iron, but i like the idea of many models in one circuit. I have not got wiring diagrams from VT or later Holdens, are they the same ALDL connector as the VR/VS? - Thanks for the reply.
