Delcos 3.6L starlet
Discussion in 'Projects' started by delcowizzid, Oct 12, 2019.
  1. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    So some of you that have stumbled through my other build thread may have come across this before .was a buick v6 turbo build but plans changed when a tidy cheap vz motor and box popped up so now going hard out cutting **** back apart to fit the new combo
    Slowvxss, Deuce, VS_Pete and 3 others like this.
  2. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    Tight as a mofo....thought my lc with efi 304 was bad enough lol
  3. delcowizzid
    NZ
    в∞ѕтεכ √&
    It's not too bad plenty of room for headers its a bit taller than the block it had and the sump took a bit of cutting to get it low enough to close the bonnet.also had to cut the firewall back out as the heads go further back in proximity to the bellhousing flange compared to buick where the heads are 50mm foward forward of the bellhousing surface.
  4. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Looking forward to seeing more work on this.
    VS_Pete and Lex like this.
  5. EYY
    EYY Well-Known Member
    VS Statesman
  6. delcowizzid
    NZ
    в∞ѕтεכ √&
    Yep of course haha
    VS_Pete likes this.
  7. EYY
    VS Statesman
    What's the plan for making it boost friendly? Gonna run ethanol with stock compression?
    Full send?
  8. delcowizzid
    NZ
    в∞ѕтεכ √&
    Will be run on Avgas stock engine and twin turbo if I can quickly find 2 matching turbos .and hoping to do an ecu swap to vr auto ecu and run the motor and 4l60e with it
  9. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Good plan.
    I'm definitely keeping an eye on this one!
  10. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    I'am too!
  11. delcowizzid
    NZ
    в∞ѕтεכ √&
    I would upload more pics of the progress but phone pics are too big for the forum wtf lol
  12. delcowizzid
    NZ
    в∞ѕтεכ √&
  13. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I take photos a bit further out and then crop them down. This seems to cut off enough size for it to take them.
  14. ephect
    ephect Donating Member
    VS Acclaim V6
    Fk ur a crazy mofo! I love it
  15. Lex
    Geelong Victoria
    I use one of my old phones.
    I can lower the mega pixels down to l think 6 or 8 mp, & that works for me.
    Two mp & above wouldn't load to the JC web site, but under that would.
  16. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    I email them to myself and select large. Bit of mucking around and annoying at times because its only every 5th or 6th photo that won't load.
  17. VS 5.0
    Or use a 3rd party hosting site like Imgur.
    VS_Pete likes this.
  18. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    Now that's a little bit different and I like it, what power figure's are you hoping for.
  19. VS_Pete
  20. delcowizzid
    NZ
    в∞ѕтεכ √&
    Eventually around 500hp at the tyres but will sneak up on it like I did with the buick in the vb
    losh1971 likes this.
