Converting VY Ecotec to L67
Discussion in 'V6 Development And Modification' started by Darkness1990, Jan 12, 2020.
  1. Darkness1990
    Darkness1990 Member
    Boronia Heights
    VY Commodore 3.6 ecotec
    Hi, I would like to convert my VY into a L67 manual. Ecotec in it has 175k on the clock. Problem is I'm finding it really hard to pick up a factory VY L67. I would like to get a manual box with the L67 and loom etc if I can But if not I guess I'll have to buy a manual box with loom conversion kit and convert my auto to manual then put the L67 in?
    Any advise about converting my ecotec auto to L67 Manual?
  2. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    The only easiest way, would get a Monaro L67 and Manual box combination and drop it in, I thinks classed as a CV6 ?
    Otherwise you will need to keep searching, and get bit by bit and assemble it,
    Keeping in mind, try and get the original ECU with the L67, as it will make it a bit easier to fire up after its programmed correctly.
    Taking into account, you will need to bypass the Auto inhibitor switch/mechanism,
    I think there is a different loom for that.
    Darkness1990 likes this.
  3. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    There was no factory option for a manual transmissions with L67 so you will need to do your own conversion.
    Fu Manchu and Darkness1990 like this.
  4. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    T56 conversion will handle l67 with ease....budget not so much.
    Did vy 6cyl model get getrags or auto only?
  5. immortality
    Sth Auck, NZ
    I see VY manual tunes in my database so it must have been an option.
    L67, T56 with 3.9/4.11 gears Yes Please!
    losh1971 likes this.
  6. krusing
    I think most of the L67’s had Auto’s,
    we’re manuals were an option.
  7. gtrboyy
    vt ss & lc gtr
    There were no L67 manuals that I ever saw otherwise vs model would have had & been sought after.
    Thinking about probably manual v6 utes out there can't say I ever noticed factory manual v6 sedans.
    Fairly sure Mal Woods & Dellows have the gear to do t56 conversion...years ago had a getrag in v8 torrie,liked it but if it ever broke rather go t56 than replace it especially after looking at availability & price of flywheel/clutch replacements etc
  8. Darkness1990
    Darkness1990 Member
    Boronia Heights
    So after some more thought and information you guys have provided. I'm thinking of stroking my ecotec to 4.2l and then go turbo with a T56 manual and short shift kit.
  9. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    There were no factory manual L67's full stop.
  10. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Up to you but stroker will cost you $5k + if you do the assembly yourself and won't make a huge amount of extra power. Intercooled twin turbo on the other hand will make a huge difference. Go Turbo and don't bother stroking.
    Fu Manchu likes this.
  11. Darkness1990
    Darkness1990 Member
    Boronia Heights
    Yeah I'm not so worried about the cost as its a project car anyway and will be done over time. I'm thinking T56 and stroking it first with forged internals then later on add PCM from LS1, Garret gt3540 turbo and intercooler and twin surge tank.
