cheap black 202 mod
Discussion in 'Straight 6 Development And Modification' started by VKCOMMO, Aug 11, 2009.
  1. VKCOMMO
    VKCOMMO Carpark Mechanic.....
    Springwood, NSW
    hi
    i have a black carbed 202 in a vk and im looking for some cheap modifications to give me more power
    thanks
  2. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    EFI or Carby?
  3. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    put a rb30 or V6 into it, can cost less than a grand, id call that pretty cheap considaring the gains.
    Im doing it:thumbsup:
    EDIT: It's carby tom^^^^^
  4. TR33VV
    TR33VV Hummer and a chicken feed
    Sefton Playhouse
    VY SS II LS3+TURBO
    :thumbsup:
    Exhaust, headers, Holley or triple SU's, cam, headwork, etc...
    Or as above RB it... ;)
  5. Tom_1569
    Gippsland - VIC
    '14 SR5 Pusslux
    Tottally missed the carb bit, Im suprised I was even able to post last night :p
    CHEAP mods....
    34ADM Weber Carby, great for power and economy - Shouldnt cost anymore then $150 to get everything done, shop around you could do it for under $100.
    Scrap the EST and fit a Blue Motor, or VK EFI Dissy - $40 - Great for realibility, slightly more responsive and better on fuel.
    Fit electric thermo fan - Under $100 if you shop around, about $300 if you go all out and use AU Thermo Fans.
    Extractors - $50 + Fitting
    2 1/4 Inch exhaust - $250ish
    Then you can look at removing, power steering, air-con emmisions and **** if you feel the need. But thats about the limit without opening up the engine, and less you bolt a dirty supercharge on, or a turbo.
  6. VKCOMMO
    Springwood, NSW
    thanks guys.. will look into it
  7. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    Try putting one of these on
      File size:
      118.2 KB
      131
  8. VKCOMMO
    Springwood, NSW
    not 100% p-plate friendly
  9. mr5000
    mr5000 mr5000
    mooroolbark ,melbourne
    lx torana
    pull the head of or get a nother head get some work done to it put a cam in extractors carbie manifold and decide whether you want eventually want to go all out or if its just piss farting around till you get a v8 if ya serious then go tripples if ya mucking around go a downdraught webber or ww stromberg
    no need to go rb or anythign the 202 has a fair bit of punch if ya do the right things to them
  10. fat084
    fat084 Member
    vk 84
    try changing the spark plugs LOL
  11. VKCOMMO
    Springwood, NSW
    already put a new set of plugs in. just piss farting so maybe just new carb.. thanks
  12. coryu1
    coryu1 New Member
    not sure you really need a new carb if you havent done anything else to it?? the fan would be the best bang for your $, then changing the diff ratio?
  13. VKCOMMO
    Springwood, NSW
    ok.. thanks
  14. Guzzoline addict
    Guzzoline addict New Member
    vr v6
    The exhaust choke on vc to vk sometimes seizes shut,take it out or unseize it.
  15. VKCOMMO
    Springwood, NSW
    k. and how is that done?? thanks
  16. Guzzoline addict
    vr v6
    First check if it seized. the exhaust choke is between the exhaust and the manifold on one of the pipes .If it is not seized best of leave it alone. The hard part is getting the exhaust of the manifold without snapping the bolts. When u get the choke out the easy way is to cut the butterfly of the shaft. If snap the bolts on the manifold get extractors.
  17. VKCOMMO
    Springwood, NSW
    thanks....
