Carby Backfire and Valve timing - Need Help!
oshi16
Gosnells, W.A.
85' VK 202 Carby
Hey Strgas,
Good points. And a good question; I think it happened due to the brakedown; I forgot to mention that another main factor...well THE main factor of the brakedown was that the heater hose sprung a leak, and slowly drained the coolant. The engine fried as I jumped on the freeway and as I got to about 100 BOOM! And all the symptoms of a blown head gasket (even though this was not the problem). a rapid drop in revs, eradicate revs, black smoke pouring out the exhaust and a crap load of coolant sprayed everywhere under the bonnet.
I got towed home by RAC (lifesavers!) and I tried starting the car (as it was cold) in order to get it about 10 meters; from the front yard - into the shed. And I'll be buggered it actually did start and run...just sounded a bit odd...and I only drove it for about 15 seconds and never touched it since. After much inspection (and through my recent lack of experience and knowledge) I decided it must be the head gasket (WRONG) and disassembled the motor.
I think the bridge may have been damaged a few months back (probably about 5 months or so) when I put in the electronic dizzy. I changed it over and started the motor to be confronted with a large pinging noise...like the valves were hitting the top of the rocker cover (which they were)...It turned out that I had an oil leak that turned serious when I replaced the dizzy (it was from the rocker cover gasket, that just decided to break down at the back during the previous couple of days I didn't drive it) (PS...it was on the grass when it leaked, so I didn't see the oil). And I topped the oil up to full (from damn near empty! and she ran like a dream). The Next day I replaced the rocker cover (lost a bit of oil over night which I caught under the car with a tub, and then replaced.) and found that there were a few small dents on the back roof of the rocker cover, and marks on the 4th and 5th valve heads (5 especially)....but being inexperienced I thought nothing of it (it was actually the first time I've ever taken a rocker cover off!)
Looking back, I have made many ignorant mistakes; and I'm trying to make a mends for them as best I can. But for now I want the car running sweet; and I'll controllable add upgrades one at a time (I.e I've got a carby rebuild kit for the weber siting on the shelf).
Thanks for all the input guys, I really appreciate it!
Brendan
oshi16
Gosnells, W.A.
85' VK 202 Carby
Hey Guys!
Sorry about the late reply.
First: Thanks a hell of a lot to all of the posters! I couldn't have finished this project with out your advice! (probably would have gotten weak and went to a dreaded mechanic; I don't know any good ones!)
Second: It Lives! Turns out it was the cam timing; on TDC (compression stroke) the rotor pin (button) was 180 degrees the wrong way, trying to fire cyl 6 instead of 1. So I swapped em around; turned it over AND.....it tried but didn't go...Like hell I said! *Grabs can of 'Start ya bastard!'* Using that and fiddling with the dizzy timing (spinning to adv or retard) I got it running! And It sounds sweet! (beefy!) and runs like a dream... =)
Thanks again to everyone! I'm sure I'll be on here again sometime soon to help others with vk problems!
Brendan
ari666
250,000 hits
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Hey Guys!
Brendan
No, ignition timing. Glad you got it sorted though, well done.
oshi16
Gosnells, W.A.
85' VK 202 Carby
Oops...yeah I meant Ignition Timing...lolz. And Yeah the 180 deg. out is so freaking easy to do....I hope I don't repeat it...But if I do, I'll know where to start!
Have a good Weekend Guys!
