Car Struggling to Start
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by DeathSammich, Jan 1, 2018.
  1. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Ive just finished an l67 rebuild, Put new injectors in, new coils, tried multiple DFIs, new plugs and have tested my spark leads and, injector pulse, coil resistance and all. It goes pretty well when it goes but seems like it has a slight misfire. But when you turn it off and try to start it again it struggles to start, the plugs turn black and you can smell fuel? You can get it to go a couple more times before it can't fire at all, each time struggling more and more. What could cause it. I'm waiting on a scan tool to be delivered though
  2. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Are the new injectors the same size as the original injectors? Checked the fuel pressure?
  3. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Yes they're standard l67 injectors
  4. immortality
    Sth Auck, NZ
    Have you checked to see if you have an actual spark? To check, crank the engine with the fuel pump relay removed and one plug out of the engine to check you are getting an actual spark.
    Also test fuel pressure.
  5. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Well I must be because the engine tries to actually go like it stumbles and stuff but won't actually fire properly
  6. immortality
    Sth Auck, NZ
    Well there are 2 options, **** spark or to much fuel.
    you running standard tune and maf?
  7. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Yes that's correct
  8. immortality
    Sth Auck, NZ
    Check your fuel pressure.
  9. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Did you replace the fuel filter when you did the injectors?
  10. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Nope it was a fairly new filter
  11. EYY
    EYY Well-Known Member
    VS Statesman
    Standard L67 tune or ecotec tune?
  12. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    I believe it is the l67 tune but I could of mismatched them? Code on it is dblco ddrh 2640? Don't know if it means anything
  13. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    i would suspect incorrect injectors
    check the code on them
    when you say l67 rebuild
    was this car always l67 and how much of a rebuild
  14. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Car was always rebuid, new forged rods and pistons. Injectors are Bosch
  15. devilly
    devilly Guest
    I had a problem with injectors I found that you also have to match the other numbers so if it says C and you have taken out an A <--- example. then it can cause misfires and not run correctly heck I even put in v8 to my v6 by mistake it wouldn't start and had black smoke from the exhaust system. could be the purge value solenoid. have you done a fault scan yet ? injector leak down test ? or might be the re learn thingo.
  16. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Ddrh is vx supercharged tune.you don't have a hole in the fuel pressure regulator diaphram by any chance.or Chinese injectors they are bad for sticking open and closed
  17. delcowizzid
    NZ
    в∞ѕтεכ √&
    Is it a stock rebuild or what
  18. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Pretty much expect forged rods and pistons. Injectors must of been knock offs because they were only $160 so I got a set of used genuine Holden ones. Got this fault when scanning though
  19. delcowizzid
    NZ
    в∞ѕтεכ √&
    That would make it start bad when hot for sure
    DeathSammich likes this.
