BMW X5 rims on a VZ
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by JaydenVZwagon, Mar 4, 2017.
  1. JaydenVZwagon
    JaydenVZwagon New Member
    Newcastle
    2006 VZ Executive Wagon
    Will BMW X5 wheels fit straight onto my vz wagon with low profile tyres on them or will there be issues with hub size becuase I know the stud pattern is the same
  2. Sandman
    Sandman Challenge Accepted
    HQ VC VZ
    Depends on the offset and tyre size
  3. Trayner
    will probly need to run spacers as well
  4. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Years ago, I put a steel 15" VZ wheel on the rear of an X3 BMW....Straight bolt on......Had to do it because the owner of the car got a lump of metal through a tyre, which stuffed the rim.....And being an European car, it came with a can of slime and an air compressor for a spare.
  5. vc commodore
    south australia
    vc commodore
    Which you can't legally do
    the_boozer likes this.
  6. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    A lot will depend on the offset.
    To keep them inside you body work they would need to be no less than around 35P with a narrow tyre and 45P with a wide tyre.
    Early X5 rims ran 20-25P offset which required Adventra Flares to cover the wheel and tyre.
  7. graham7773
    graham7773 Active Member
    VT Acclaim Wagon
    So does this apply to all BMWs? I am looking at a set of rims off a 320 I90 and I have been told they fit. Yes/No?
  8. harrop.senator
    harrop.senator Well-Known Member
    perth
    vr senator 355, vu 5 speed l67
    This is 18x8.5 +15 off an e92. I had to roll the front guards about 30mm and -2 degrees camber up front. Its running a 235 40 18 with a fairly stiff suspension set up, I had to lip the rears flush and put very stiff springs and bilsteins in or itd sack and rub the on the upper wheel well curve when you got off stall.
    Vr-vs seem to fit more rim then vt-vz. On holiday at the moment and have no photos of the wifes vu. Im running 16x7 + 20 bbs ra off an e34 on thise and its not been driven with them yet as done an engine conversion and interior conversion thats not yet complete. But pending how much front end resets ill probably need to kip front guards and add 1.5-2 degrees neg camber
  9. Surfwagon
    Sydney/NSW
    The offset of the BMW rims changes with nearly every model.
    It will be stamped or embossed on the inside of the rim along with the actual width.
    I have all more guards rolled and run the following.
    8"x18 35P on the front with 245/40 tyres and if you put a straight edge on the tyre it sits slightly outside the guard.
    Rears are 9"x18 45P (almost same as Holden 48P) running 275 tyres dead in line with guard.
