any thoughts on CPR 6 manifolds
Discussion in 'V6 Development And Modification' started by commodore665, Mar 25, 2017.
  1. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    hey , I've done a bit of digging , and there seems to be a lot of differing opinions on the CPR 6 manifold , looking at them , it looks like they are better at high revs , and as most people are not going rev their engines that high for long periods , I'm wondering are they a viable option for then way the average Joe Shmo drives .
    any thoughts welcome .
  2. immortality
    Sth Auck, NZ
  3. commodore665
    yeah pretty much what I was thinking too , probably a good support mod for forced induction , but on a N/A engine below 3000 + RPM , not a lot to gain , may look at diff gears then ,
    cheers
  4. immortality
    Sth Auck, NZ
    I think the CPR6 is probably a great mod for any engine that wants to rev.
    Do you know what the diff ratio is in your car?
    If yours is the 190 with the 5 speed auto they have 2.87 gears in the diff but the 5 speed has a much better gear spread between 1st - 2nd - 3rd unlike the 4 speed auto. Even some 3.08 or 3.45 gears would really wake it up. I do believe the V6 still has the smaller diff fitted so need to be careful there when looking for gears or a diff to swap out. A 3.46 ratio diff from a V8 model would fit but you would need to swap the pinion drive flange coupling over as the V8's have the larger M80 diff which uses a larger coupling than the V6 but I would suggest looking under the car and confirming the size of the doughnut rubber coupling to be 100% sure of what you have or what you need.
  5. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Would probably just end up being one of those mods you can tout as a name on the list of stuff done to the car and wouldnt end up doing a whole lot unless the parameters were 100% right.
    At tradeschool we had a 5.0 that was stock, did a baseline run and then chucked the old Starr manifold on. Think they were around $2k when they first came out???? power increase on a stock motor was 6kw.
    Not real good $$/kw. Im sure if the motor wasnt stock and had a bunch of supporting mods the intake would have helped but, it's a big chunk of $$ to only work in an ideal environment.
  6. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Not worth it unless your going forced induction. It's basically the last thing your really upgrade.
  7. commodore665
    yeah pretty much what had thought too , I'm not prepared to go down the road of forced induction on a V6 , may look at at diff gears as immortality had suggested , thanks for the input though . In reality they are probably a bit of wank to be honest , I was kind of curious about them
  8. commodore665
    yep it's the 190 with 5 speed , thanks for the information mate , much appreciated .
  9. Trayner
    Just get some Mace Spacers for it , Wont get any extra power out of your car . But it will move the power band down abit lower in the rev range . So will "feel" like you have a few more balls.
  10. commodore665
    actually , I already have the 25mm spacers , plus the CAI from Mace , with those combined , it breaths easier and a bit more down low , and a nice induction growl , but thanks all the same .
  11. commodore665
    and also thanks to you too Sabb .
  12. Revhigh
    Revhigh Member
    Dandenong South
    Holden VF Maloo
    I have an alloytec, had a set of 12, 18 and 25mm spacers. 18mm worked a treat
    Since then I have fitted the CPR6 with a set of 5mm spacers we made and to be honest the car feels like a beast to drive now compared to before.
    Mod list
    - CPR6
    -5mm spacers
    -Underdrive pulley
    -Stealth 3.0 Controller
    -Port matched
    -Revhigh Stealth Camshafts
    -Dyno Tune
    Still waiting to put my paxton back on with larger injectors but been caught up.
    All in all I think its worth it. Send me a PM for any pictures.
    www.revhigh.com.au
  13. Revhigh
    Revhigh Member
    Dandenong South
    Holden VF Maloo
    Oh and I have an OTR as well!
  14. Capsule
    Capsule Member
    Brisbane, QLD
    MY09 VE Omega
    Wouldn't you feel the CPR6 gains earlier if you already have spacers, OTR, extractors and exhaust? Would be curious to see a dyno comparison with these mods instead of a bone stock engine.
    I remember I could really feel the extractors kick from 3500 when I fitted them, while the stock exhaust manifold was feeling flat and even loosing torque after 4500 (actually, you can see that on the graph).
    I reckon extractors + CPR6 would be even more noticeable.
