ALLOYTEC VZ 06 AC Stuck on Demister?
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Bardy-II, Jan 17, 2019.
  1. Bardy-II
    Bardy-II Member
    Frankston, Victoria
    VZ Wagon
    Hey, so I'm trying to figure out what is going on with my VZ AC system.
    So far I've replaced:
    - Resistor Block
    - All 3 centre dials
    Fixing these two I've managed to get the 1,2,3,HI setting back which is great, but now it's stuck on the front demister? I double checked to make sure everything's plugged back in and all the vacuum hoses are in at the dials, but to no avail. Not sure where to go from here!
    I've heard about the vacuum hose on the back of the inlet manifold but not sure what hose I'm looking for? If someone could include a picture that would be awesome, I'm kind of competent but not so familiar with these vacuum systems!
    I'm only posting this because all I've seen so far are for Ecotecs, and a lot of the VZ posts are very vague in regards to the problem and the location of the hose!
  2. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
  3. Bardy-II
    Bardy-II Member
    Frankston, Victoria
    VZ Wagon
    Replace the main vacuum actuator down in the driver's footwell?
    Might as well give it a go, can generally pick one up for $10 at the wreckers, thank you!
  4. Fu Manchu
    WA
    VZ V6
  5. Bardy-II
    Bardy-II Member
    Frankston, Victoria
    VZ Wagon
    Where about is the check valve?
    Left side of engine bay close to brake booster?
    Ah okay awesome, thanks!
  6. Fu Manchu
    WA
    VZ V6
    It's near the brake booster.
    On another point, the vacuum actuator is on the drivers side just behind the lower trim panel on the centre console/lower dash.
  7. Bardy-II
    Bardy-II Member
    Frankston, Victoria
    VZ Wagon
    Okay awesome, driver's side of the trans tunnel in the footwell :D
