Alloytec Random multiple misfire cyl 1,3,5,
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Relax98, Jan 14, 2015.
  1. Relax98
    Relax98 New Member
    Yarrawonga
    Vz Berlina
    Hi all, I understand this is a VZ section, but was hoping someone may have a solution to my issue.
    My in laws car 08 Ve alloytec has came up with p0300 random misfire fault, also cylinders 1, 3, 5. RACV told them that two coils were gone and had to be replaced. So I got the job to replace them, only to find fault still comes up. I put 2 new coils into 1 & 2 fitted 2 into 3 and swapped 4 with 5, the fault still did not change. I also checked the spark plus and they all seem fine NGK platinums so I assume they have been changed. The car has 153000 on the clock. It has also had the right side cat changed for a previous fault, one O2 sensors also for another fault. I have tried searching posts on this but haven't been able to find a solution. The car starts fine every time but once revved over 2000 the miss comes back and the left bank is shut down. So after some more investigation tonight I found a vac leak coming from 90 degree fitting at the rear of the drivers side valve cover. The hose goes to a tee then one hose to each side of the plenum. I blocked these off but found no difference, I didn't expect to but worth a try. I then plugged in my code reader and reset the fault and noticed some variations between STFL B1 12.5% and STFL B2 6.25% average fluctuating but B1 always higher.
    I also noticed differences with the O2 readings, o2s 11 0.360v -14.85%, o2s 12 0.465v 99.21%, o2s 21 0.690v 11.71%, o2s 22 0.480v 99.21%. Not sure if this info is of any use but may mean something to someone clever on here. Any help appreciated, It is about to be sent to holden to see what they say. $$$$$ hopefully not.
  2. madute
    madute Member
    Perth, Western Australia
    VZ Storm Ute
    I'm no expert but the last time a mate had an issue like this it was a bad injector was clogged.
  3. diysv6
    diysv6 Member
    SEQ
    VF S1 SV6 STORM A6: VZ S1 SV6 A5
    I have a 2004 Alloytec so the locations could be the same in the VE, but then again Holden may have configured the earthing in a different manner.
    So this is the 2004 Alloytec offering.
    The earth returns for the ignition coils for cylinders 1,3, and 5 are commoned together and bolted to an earth point on the outside rear of the odd cylinder head. If the fault is unlocatable then look at the wiring carrier which runs on the outside top edge of the cylinder head. Out of the carrier will come the ignition coils connectors etc. Also out of the carrier is a wire going to an earth bolt at the rear of the cylinder head. I had checked mine when my ECU was failing. The earths are commoned up inside the carrier and a double wire from memory goes to the earth location. If the lug crimp, terminal bond to the aluminium head is corroded then the coils could fire erratically with engine/exhaust temperature changes, vibration, water splash access etc. Do they use an aggressive high pressure engine degreaser at all?
    Similarly the cylinders 2,4 and 6 coils are earthed on the other cylinder head to the rear of the oil filter housing.
    I hope this may help if you get nowhere with the fault.
  4. Relax98
    Relax98 New Member
    Yarrawonga
    Vz Berlina
    Thanks Diy I will check the earth point, there is one towards the front of the drivers side bank, last service notes did mention engine de-grease / clean. I will be sure to post when I get a possitive outcome.
  5. Relax98
    Relax98 New Member
    Yarrawonga
    Vz Berlina
    Cleaned earth points ( 3 ) along bank 1. no change. Holden mechanic suggested injectors so I have changed from one bank to the other... no change.. I am starting to think it may have something to do with the ECU anyway back to Holden on tuesday, I will post the outcome.
  6. Ve2007jf
    Ve2007jf New Member
    2007 VE Commodore
    Hi, did you ever find out what the problen was cause i too am having a similar problem, i thought it could have been stretched timing chains and replaced them myself using a workshop manual, but it didn't change a thing, still coming up with faults on one bank of cylinders
  7. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    If you or a family member are paid up Auto Club members, make a call and get them to send a 'mobile mechanic' for an opinion. Most Auto Clubs also offer a diagnostic service (for a nominal fee). Perhaps for the cost of membership you might consider that as an option. Might turn out to be a lot cheaper. Holden Dealers know how to charge !!
  8. Trax 211
    Trax 211 New Member
    Wangaratta Vic
    Wm statesman
    A very common fault with the alloytec engine which creates a whole bank misfire is a sticking vct actuator solinoid. Depending on the engine some have 2 per head or only 1 for each head. They are bolted in the front of the head using a 10mm headed bolt. Try swapping them from left head to the right. When they are removed check the gauze and make sure they look clean. If the misfire changes banks you know what the culprit is. The issue is that they will open under high oil pressure/higher revs but can't close when the revs drop due to carbon deposits in fine tolerance components creating a valve timing issue and misfire due to camshaft not returning to the correct position.
    Luke Bennett likes this.
  9. wraith73
    wraith73 I see dead people
    VE SV6, Nissan Patrol, Grand Vitara
    I've got an issue with my father in law's VZ. Used to 'splutter' a bit at around 80kmh. Over the last couple days, on acceleration, the check drivetrain warning came up and it started running like a Ford. Barely stayed running at idle, and takeoff slow and rough. Connected up a real time scanner, which came up with codes P0300, 304 & 306. While idling and going thru codes, i hit wrong button on the scanner, and erased codes. Immediately, the car idled perfectly smooth with no faults. The faults eventually came back, but each time, she ran fine as soon as I pressed erase. Seemed a bit odd to me. All the wiring and connections, as per other posts, seem fine. All I've done recently is add a tin of injector cleaner (Liqui-Moly). He's hoping to sell the car, but can't really do anything until these issues are fixed.
  10. Big Red VF-SII Go-kart
    Big Red VF-SII Go-kart I love puddles.
    Geelong VIC
    VF-SII SV6 (MY017) Sportwagon
    That's interesting. Very, very interesting.o_O
  11. Luke Bennett
    Luke Bennett New Member
    Perth wa
    Vz V6 ute
    I have the same issue. Please let me know what you did to fix this. I have replaced coils . Can sensors . Spark plugs . Now ecu and still missfire on cylinder 3. 1 and 5 are ok since replacing ecu . Brand new cost $1100.00 . Need help.
  12. Luke Bennett
    Perth wa
    Vz V6 ute
    Maybe if I try replacing the vct actuator solonoid it might fix my issues. Same issue as posted above. Replaced ecu in the end and its now made 1 and 5 work but 3 still missfiring ... Not sure what else it can be. Have replaced plugs and swapped over injectors l and coils making no difference. Could it be possible that the cam position sensors still work if the solonoid is sticking ? I ask this only as I changed the cam sensors from either side and it made no difference.
  13. greenacc
    greenacc Searching for the billion
    VE Berlina
    You might have to clean the tip of the vct actuators. I haven't done it myself but I think to there's a bit of a procedure to follow.
  14. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    Have you tested the wiring to the coils?
  15. kungfumike
    kungfumike New Member
    VE Calais 3.6 SIDI
    Hey guys. Was there ever a solution found to this problem ? Mine has just started doing the same... new plugs, swapped this and that, the usual blah blah... about to swap engines to stop me having a hissy fit and taking a hammer to it but would like to try everything first.
  16. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    shits ya with no follow up but have a look at those vct things post
  17. kungfumike
    VE Calais 3.6 SIDI
    Yeah, no good. Stays the same side.
