Alloytec Pcv valve removal
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Nick86, Jan 17, 2020.
  1. Nick86
    Nick86 New Member
    Kyabram
    1995 Vs Commodore Berlina V6
    Hello everyone i've recently read up how drilling out the pcv valve can benefit performance and allow the engine to breath more efficiently. But i am having trouble removing it as it seems stuck. I have seen many videos where people remove it with ease. But i cannot get it out, i have tired pulling up on the valve spraying wd 40 around to try and remove it even trying to pry underneath it to no success. Is there some type of way to get it out? or is it glued shut to the valve cover?
  2. ant797
    ant797 Active Member
    bunbury
    vy s
    its proberly seeled to the grommet try turning it 1st in the grommet to brake seal before then wriggle it out might need a new grommet if it has one proberly baked
  3. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    there stuck in with red threadlock i used a set of multigrips twist and pull can cover with a rag if u dont want to damage it or get a new one from holden 40 bucks here is the part number GM#12583384 or acdelco
    dont know if your read this thread https://forums.justcommodores.com.au/threads/alloytec-pcv.279039/ all the info is in there
  4. greenacc
    greenacc Searching for the billion
    VE Berlina
  5. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    There is a bit of red thread lock on it. The valve needs to be given a little twist to break the thread lock and then it will come out.
  6. Fu Manchu
    WA
    VZ V6
    Yes Vise grips are a must.
