Alloytec PCV Problem/Fix
Commowar
Tasmania
vz calais 3.6
New thread begun. Sorry got carried away, I was just following the natural progression of this thread ;-). You posted a sump pic and got us all scared so now I've gotta follow suit haha. Cheers
mickwebs
Warrnambool
VZ Lumina Wagon
great thread thanks just finished doing mine on the VZ Wagan I brought last week totally blocked. the manifold inlets had red grit had to use a drill bit in my hand to get it out. oil in the intake. It was rough idling hopefully it will be better maybe chains next. only done 233000 km's this forum is great for all the fixes.
shueardm
VZ SV6
just did my PCV mod.
Was not blocked but restricted in one of the holes.
Was dirtier than I expected at 172000 k with me doing regular full synthetic changes at or before 7500 interval since 60k ownership. I guess that first 60k is a blank though
Glad I did it. Was very careful on the drill and took long time for the top hole but the bottom holes were quick. 7/64and 5/64 bits used.
figjam
Donating Member
Port Stephens area.
Monaro CV8, Cross 6 Crewman, Territory Ghia.
I am going to have a go at doing this, and have ordered the part as shown in @scaredyet's post # 58 ......... told them that the part # referred to a Chev Camaro V6 pcv valve. (which is easily available in the USA)
I just picked up the Fitting PCV from Holden. It's a Genuine part (GM# 12583384) Made in Canada. I'm not sure if it's the revised part with the bigger holes.
I Paid $40 from Holden Spare Parts in Sydney. So you can definitely get that part from here without having to buy the whole cover.
The Cross6 is a May'05 build, and the Holden parts rep showed me what came up when he put the VIN to their computer.
Yep, I should buy the lot costing $$$$ o_O , and the parts diagram showed a PCV valve which looked a bit like this ........
Fuelmiser PCV Valve Fuelmiser - OES - PCV-009
and on looking at mine on the engine, it does seem to resemble that, and a bit of twisting and pulling to remove it seems dangerous. The flange seems to be inset into the cam cover.
Do I have something 'different'. Are the PCV valves all the same, or could early built engines prior to the timing chain fiasco use a different PCV valve.
figjam
Donating Member
Port Stephens area.
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
We have an ‘04 VZ as well, it is the same old PCV in the cam cover as all others.
Fu Manchu
WA.
