Alloytec, no power going to fuel pump.
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Oropi-Commy, Jan 14, 2020.
  1. Oropi-Commy
    Oropi-Commy New Member
    Laverton, WA
    VP Toyota Lexen
    Hello all.
    I am trying to get a vz crewman going that has been sitting around for a few years and have hit a bit of a block. I am not getting any power to the fuel pump. I have tested the pump and it is working. When I turn the car on or crank the engine I get no voltage at the plug. I am also not getting any voltage at the fuse or relay. I have recoded a new key to the standard pcm and that is working ok.
    What am I missing?
  2. mechanic
    mechanic Member
    Australia
    Commodore
    You answered your own question.
    Which fuse did you check?
    Which relay did you check? How did you check it?
