Air-Con Pressure Issue
Discussion in 'VF Holden Commodore (2013 - 2017)' started by ciggo, Jan 22, 2020.
  1. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    Fair Call, I can under stand that $140 isn't much,
    however, its all done by machine now, with next to nothing labour content,
    that is connect the hoses, de-gas it is done automatically with a press of a button,
    And very similar with re-gassing.
    Again, no disrespect to the honest A/C Techs, as I met a fair few over the years,
    Especially the ones I knew in the Electrical Trade, they were good, and knew their stuff,
    but hung up their hoses and gauges and retired.
    But the cowboys are the ones giving the Refrigeration trade a bad name for all Fridgies.
  2. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    I don’t know either but I’d guess EPA refrigerant handling regulations and the need for licensing to work on air condition systems may have reduced the interest considering how much people are willing to pay for aircon servicing :rolleyes:
  3. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
  4. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    They don't use old refrigerant, most licenced places have strict guidelines and all service records logged and gas returned to the correct facilities, people use all sorts in their system from Hychill minus 30 to 134a some even try putting other things in like propane, the old stuff would be contaminated with all sorts, it cost them to send the old stuff back just like a tyre place has to charge in disposal of old tyres.
    Never herd of a dryer exploding, Have herd people replacing A/C compressor and blowing them up due to condenser blocked therefor oil not getting back to the compressor.
  5. krusing
    That's when it leaves you with the decision to say,
    You want something done properly, do it yourself,
    Many a time the Holden dealers I have dealt with over the years, have come unstuck with egg on their face's,
    Not completing everything on the lists, that they said they completed on the service invoice,
    provided it was all done, I didnt mind paying the invoice, but I wont be ripped off.
    Fu Manchu likes this.
  6. Fu Manchu
    WA
    VZ V6
    And there it is. The Hychill rep
    losh1971 likes this.
  7. Fu Manchu
    WA
    VZ V6
    I think by pressure OP means airflow from the vents rather than actual pressures in the ac system or this forum.
  8. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    That's what I understood it to be Fu.
  9. Trevor loves holden.
    vs commodore
    Your quick to change your opinion.
    I would say the vacuum line valve got stuck open either by freezing or just didn't operate right, shutting it down fixed the valve flap..
  10. Trevor loves holden.
    vs commodore
    Nope still have that toxic 134a refrigerant with that toxic PAG oil that makes mustard gas in the right conditions.
    I'm thinking of going to Hychill next service due to better engine performance and cooler vents and no toxic substance that can rust out your A/C system if the moisture happens to get in, also longer life out of your compressor as it stays cooler and doesn't get as hot as 134a running through it.
  11. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    You need to read what you quoted, Fu stated amount, not pressure...
    Also, there are no vacuum actuators in VE/VF.
  12. Trevor loves holden.
    vs commodore
  13. Forg
    Forg Well-Known Member
    Regal Peackock VF SS-V Redline Wagoon
    Electric motors have GOT to be more reliable than rubber sucky-sucky tubes kinda/sorta sometimes (when they feel like it) pulling a valve mostly-shut.
    Effing 70's Volvo still leaks hot air into the HVAC on really hot days, even though the valves are working fine & vacuum level's fine too (I initially suspect the big cam & lack of vacuum at idle - but it's not that, it's just the dumbness/inaccuracy of using sucky-sucky to close a big air valve).
    Fu Manchu, lmoengnr and losh1971 like this.
  14. Fu Manchu
    WA
    VZ V6
    Sometimes I put dangerous dihydrogen monoxide in my car wiper washers.
    dihydrogen monoxide kills lots of people every year by preventing them from breathing and it also can become slippery in the right conditions. It causes corrosion as well.
    I like to live on the edge.
    lmoengnr likes this.
  15. Fu Manchu
    WA
    VZ V6
    A small part of Sweden just died with that statement.
  16. Forg
    Fixed for modern accuracy. :)
    Fu Manchu and Skylarking like this.
  17. Fu Manchu
    WA
    VZ V6
  18. ciggo
    ciggo New Member
    Australia
    VF SSV Redline
    Correct. Original post wasn't entirely clear as I typed it quickly.
    Haven't had the issue since.
    Seems like it was just the evaporator freezing up.
  19. krusing
    Did they replace it under warranty ?
  20. krusing
    I have noticed some Radiator specialist do Air Con Servicing,
    one would assume because they have to be involved with the condensers in from of the radiator.
