AFM Question
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ssavage, Jan 15, 2010.
  1. ssavage
    ssavage New Member
    VE SSV 9.5
    i will be getting an exhaust with and otr and mafless tune in a couple of weeks but im just unsure if i will have n e problems with the afm? ive herd that when afm kicks in the exhaust will sound like crap is this true and what can i do to fix this?
    can i just get it removed?
  2. wizeabe
    wizeabe New Member
    VE Omega
    I've read that people get AFM disabled with the tune, not sure how true that is though. So I'd ask you're tuner if they've done it before.
  3. redvess
    redvess Member
    melb eastern suburbs
    VE SS
    yep exhaust sounds crap when the AFM kicks in and I have a few mates that have had it turned off with a tune ask your tuner about it when he does the mafless tune
  4. kuzman89
    kuzman89 Active Member
    vic
    VE SV6 ute
    standard the AFM isn't that great, I heard on another forum someone can 'tune' it to be much much more effective, whilst gaining power still, not relevant, but thought ya might wanna know
  5. bigjim92
    bigjim92 Active Member
    2016 VF SSVR
    A mate had his car done up by Autotechnique (VCM). They were waiting on parts for the OTR, so the exhaust went on about 3 weeks or so before the it was tuned properly, was great on 8 cylinders, but as soon as AFM kicked in it sounded ****.
    Once they (VCM) got the OTR, they tuned it all up properly but they car still sounded **** once the AFM cut in. My mate then had them disable it, and it's been sweet ever since, still economical too, until you stick your foot into it.
  6. mi04se1
    mi04se1 need for speed
    White Lake, MI
    Pontiac G8GT
    You can turn off afm with a tune. When afm kicks in and the exhaust sounds like ****, its call "drone". Here in the states, there is only a few companies that claim their product is drone fee. I got Magnaflow axle backs put on yesterday and I have not experienced drone yet or maybe the sound doesnt bother me. I heard the drone on some systems is to loud, but usually on the freeway above 65 mph.
  7. RustyCardores
    RustyCardores New Member
    VE SSV Sportwagon
    The problem with AFM is that as a 4 cyl the engine is simply not producing enough volume of gas to fill the exhaust. This allows the gasses to bounce around within the system and this causes the drone.
    As mentioned above, you can stop this by deactivating the AFM. The other option is to run a bi-modal exhaust like the Varex (XForce - Performance Exhaust Systems) as this allows you to switch back to silent running (and exhaust back pressure just like standard) on the highway where AFM is likely to be active most.
  8. bjay
    bjay New Member
    MY10 VE SSV
    Have had mine turned off since new and not a problem running full difillipo 2.5. It is a very simple and easy procedure and tuners will not charge you any extra depite what some people on here might say.:beer chug::beer chug:
