AF RACING Billet T6-6061 5 stud 5X120 69.5mm Hub Centric 15,20,25mm Wheel Spacer
Discussion in 'AF Racing' started by afracing, Jun 27, 2013.
  1. afracing
    afracing New Member
    EVO IX
    Compatible car models: Holden Commodore VB VK VL VT VX VY VZ VU VS VR and etc
    15/17mm $110.00/pair
    20mm $115.00/pair
    25mm $120.00/pair
    30mm $125.00/pair
    Postage $15/pair, each additional pair will add $6.
    Product description:
    This AF RACING wheel spacer is hub centric to suit Holden’s 69.5mm hub, it is made from the highest quality Billet 6061-T6 Aluminum Alloy, and then hard anodized to enhance the corrossion resistance. The spacer is installed with grade 10.9 studs. Pls be aware, this spacer is not built for off-road.
    Features:
    - Billet 6061-T6 Aluminum Alloy
    - CNC Machined
    - Grade 10.9, 33mm long studs
    - Hub centric to suit 69.5mm Commodore hubs
    - 120mm PCD with M12X1.5 thread
    - Comes with brand new studs and nuts
    - Sold as PAIR
    WE CAN BUILD ALL KINDS OF SPACERS.
  2. afracing
    afracing New Member
    EVO IX
    The Ebay links have been restored!
  3. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    Can you supply wheel spacers rated for circuit work and around 300rwkw? This is to suit VT commodore
  4. afracing
    afracing New Member
    EVO IX
    We run it on 500Nm+ drifting car, and no problem with that.
  5. ofrod36
    ofrod36 New Member
    Orem
    8x5
    Do you have some spares for circuit work in building the specs?
  6. alphaforce
    alphaforce New Member
    NSW
    S15
    What spec do you need?
