ABS module replacement VY 5.7L
Discussion in 'Electrical Wiring / Questions' started by Indiana Jones, Oct 21, 2017.
  1. Indiana Jones
    Indiana Jones New Member
    VY Berlina 5.7L V8 Station Wagon
    Ok, so I had a problem that now seems to be fixed, sorta kinda. ABS, SRS, trac control and Engine Check coming on intermittently (basically dash going nuts) and as has been discussed elsewhere, replaced the ABS module. All seems fine now after I got another one from Pick a Part.
    Except that I got the 2nd hand one from a VX that had the same part number, looked the same, bolted in the same etc, and I seem to have lost trac control, ie no response when I hit that button where I used to before. I tested the ABS and it works fine, but for obvious reasons, I am not willing to check whether I have actually lost airbags and similarly if not quite so much trac control.
    Are there different ones that look the same etc but do/do not have all the features or something?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    ABS has nothing to do with airbags so no need to worry about that. Some ABS modules have traction control and some don't even though they look the same, not sure about numbers.
  3. Indiana Jones
    Ahah! Thought it might be something like that. Back to pick a part and make sure that the traction control button is on the gear shift then? Or is there another way to tell?
  4. mpower
    mpower Well-Known Member
    you might have grabbed a faulty unit. Also you need the exact same unit in most cases so the numbers on the barcode on the bottom should match.
  5. VT&VX
    VT&VX Active Member
    VX Acclaim
    You might have to attempt a repair.
  6. Indiana Jones
    Ok, FINALLY got it sorted. It turns out that the Bosch sticker number is the important part. I got fooled because it is not visible once the part is installed. I also have unconfirmed reports from wreckers that some of them are interchangeable. IE they didn't have the exact one I wanted but wanted to sell me one that they said oughta work. I didn't try that for myself.
    I repost the below which was very helpful to me from http://www.pandgmotors.com.au/diagnostics/commodore-abs-part-numbers/.
    As this was a frustrating few weeks trying to identify the unit and get hold of one I have compiled the following information to assist anyone else trying to sort out their ABS problems.
    You need to match the number on your module to the replacement (unless it has been superseded – check with Holden) or you will have issues.
    Feel free to correct or add to this list if you want to – it may help someone else.
    Model Series Engine Size Notes OE Number (on product)
    COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 NO TRACTION CONTROL 0273004219
    COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 TRACTION CONTROL 0273004348
    COMMODORE VT-VX V8 5.7lt GEN III 0273004389
    COMMODORE VY V8 5.7lt GEN III 0273004962
    ADVENTRA VY V8 5.7lt GEN III AWD 0273004989 – Replaces 689 389 50725 7 -I am pretty sure this also fits Cross 8
    COMMODORE VY V8 5.7lt GEN III 0273004590
    COMMODORE VY V8 5.7lt NO TRACTION CONTROL 0273004588
    COMMODORE VY V6 3.8lt 0273004589
    COMMODORE VZ V6 3.8lt 0265800318
    Fu Manchu likes this.
  7. VT&VX
    VT&VX Active Member
    VX Acclaim
    So I will be replacing a faulty ABS with traction control (must be this one)
    with one of these..
    I have the module still attached to the pump, the fittings look the same. I was tossing up replacing just the module or the whole thing.
  8. Indiana Jones
    Well, I can tell you that I got burnt once by an absolutely identical looking unit that bolted in just fine but had a different bosch part number. Best of luck!
  9. VT&VX
    VT&VX Active Member
    VX Acclaim
    Which is what I have now, so I was planning on installing the module and pump as one complete unit. So connect the hydraulic hard lines and plug in the big connector.
    Well that is the plan
  10. mpower
    you got fooled because you failed to read my post which mentions the label that is not visible unless the unit is removed is important. Why even ask if you aren't going to listen to the advice given?
  11. VT&VX
    VT&VX Active Member
    VX Acclaim
    Thaks to Indiana for listing the Bosch part numbers that are next to the bar code.
    FYI, people reading above post, he is referring to this label on the underside of the unit.
  12. Indiana Jones
    Yeah ok mpower mate, silly me. I got there in the end and I now heartily re-iterate and endorse your advice!
  13. Indiana Jones
    Best of luck VT&VX but props must go to pandgmotors.com.au website, not me. I put that there because I find it very annoying when people don't end up putting in a resolution for others to see. Particularly when potential gremlins may arise.
  14. VT&VX
    VT&VX Active Member
    VX Acclaim
    I have been driving around with the ABS/traction module unplugged. I haven't replaced the module yet.
    I also just picked a tiny jar of lead free 'Wire Glue' from Jaycar ($10) just in case I have to repair the existing module.
    I am hoping that someone else has attempted a keyhole surgery job on that Aluminium Wire that develops the crack. Going for a 'search' now :D
  15. PaulMarc
    PaulMarc New Member
    Werribee
    2002 HSV Clubsport 5.7 litre Manual
    Have a question for you, just had my A/C regassed but the compressor wont cut in when the intermittent abs module fault lights up. i am chasing one now, but i have been told the ABS module shouldn't be the cause as they are on different circuits?
    any thoughts?
    i do know when the fault kicks in my temp gauge also doesn't work
  16. mpower
    it can absolutely do that, it's one of the symptoms.
    I had this problem myself.
  17. PaulMarc
    PaulMarc New Member
    Werribee
    UGH ok Thanks, now i am faced with trying to find one with my specific number. nobody seems to have it
  18. mpower
    some are interchangeable but not many.
    eg
    these two are interchangeable. (I know this because these were in two of my cars). VXII Clubsport Auto and V2 Monaro Auto. Having a spare to test from another vehicle is so invaluable too.
    So there may be an alternate module for you out there. General rule is stick to something that mirrors your vehicle pretty much exactly and as you can tell my two were both LS1 powered Auto's from the same year.
    PaulMarc likes this.
  19. PaulMarc
    PaulMarc New Member
    Werribee
    mine has the following sticker on it and nobody seems to have it
  20. mpower
    ironically i had a 590 sent to me when I had a broken one, it did not work so I returned it.
    if it helps i used online wreckers and did eventually find the one I needed, but this was a while back.
    If it also helps you can get these reconditioned, they slice the lid off and redo the connectors. (there are ridiculously thin wires - think human hair). But they normally do like a reco swapout not reco your unit.
