304 355/Supercharged tolerances needed??
Discussion in 'V8 Development and Modification' started by NOGEN 3, May 5, 2011.
  1. NOGEN 3
    NOGEN 3 New Member
    Deleted................
  2. sporty custom
    sporty custom Banned
    terang
    vx
    are you for real in the middle of rebuilding 355 supercharged and your asking questions like that on here yooooooooooooooooooooooooooorp sure you are ffs .
  3. NOGEN 3
    NOGEN 3 New Member
    Deleted.....................................
  4. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    set your ring gaps by what the piston manufacturer has recommended but for a supercharged engine the gaps will be a little bigger then for a n/a application, same again for the piston to bore clearance, manufacturers recommendations.
    best to discuss these things with your machinist
    forget the Haltech and stick with the delco, it's a better ecu (and save yourself a lot of coin that can be better spent elsewhere)
  5. RVK 355
    RVK 355 M0DERAT0R
    The real R series 355
    agreed there is better technical forums out there to answer this sort of a question
  6. NOGEN 3
    NOGEN 3 New Member
    Just let me know what forum is qualified to answer this question, PM me and delete the thread then and I'll ask them- easy.
    BTW thank for the advice, 'immortality'...
    How do you delete pics?
