2016 VF SV6 Twin Turbo
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Talidorian, Mar 10, 2017.
  1. monstar
    monstar Naturally as-pirated
    depths of Hays Inlet
    Peugeot 207 GTi
    Touch Up Touch Down is proper name for manual mode in the transmission control whether sequential via stick or flappy paddles.
    Yes hypereutectic so 4000 fpm given P = S x R / 6
    P = Piston speed in fpm : 4000
    S = Stroke in inches : 3.622
    R = Engine RPM : 6625
    No not forged from factory, still limited to 6600. I have JE lightweight FSR domed, forged, asymmetric slugs >5000 fpm with custom ringset so theoretical redline >8250 but is for margin of safety rather than flying to the Moon.
    426Cuda and MYVESSV8 like this.
  2. harrop.senator
    harrop.senator Well-Known Member
    perth
    vr senator 355, vu 5 speed l67
    You sure? All the print outs and tech articles i read on them were that the new gm rods are all powdered metal forged. As i was looking at upgrading the factory l67 rods with the newer forged type out of the gen v supercharged 6's in America when I built my wifes motor .
    Je make some nice slugs I've got a set lined up for my turbo Pontiac motor some of the best on the market.
    monstar likes this.
  3. monstar
    Peugeot 207 GTi
    Yes you are right, seems OEM rods are forged powder metal. Not good enough though, OEM (rods and pins) were clearly the weak link at this level, the spec was two piece chrome moly steel forged h beam design, strongest and lightest available. Well, apart from titanium!
    harrop.senator likes this.
  4. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    good on you for doing something different mate. not too many cars out there with this set up im sure.
    Great sleeper
    SuckSqueezeBangBlow likes this.
  5. Talidorian
    Talidorian Member
    Commodore Vf II SV6 Black Edition
    That's always been the plan, lsd diff next and maybe a mild cam. Then i might work on some cosmetic things again.
  6. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    There you go fixed it for ya mate lol
  7. Talidorian
    Talidorian Member
    Oh you. ;)
    vr304 likes this.
  8. bradsm87
    bradsm87 Member
    Tas
    Not a Commodore
    New tech :D
    There's no new tech in the LS3 mate haha!
  9. Riley.Davies98
    Riley.Davies98 Member
    Vf Sv6 ute
    Whats it sound like with the turbos, any chance you could put a video up?
  10. Talidorian
    Talidorian Member
    Here you go, a before with my X-Force exhaust and cold air intake, and an after with the custom 3 inch and twin turbo.
    I'll have to take another recording of inside the cabin because it sounds very different inside, you can hear the turbo's sucking in air.
    https://soundcloud.com/shannon-tratford/sets/vf-sv6-twin-turbo/s-ocESZ
  11. Riley.Davies98
    Vf Sv6 ute
    that sounds killer man cheers for that.
    Talidorian likes this.
  12. SuckSqueezeBangBlow
    SuckSqueezeBangBlow Active Member
    Heroin White VF2 SS Wagon
    sounds good. bet it goes good too.
  13. Talidorian
    Talidorian Member
    So I mentioned in the first post that the front end was a bit lower, but more specifically the air pipes from the intercooler to the turbos have been run underneath the cross-member it's sitting about an inch lower than the cross-member, and added onto that the front end weighs about 100kg or so more than it did stock.
    Due to all these factors, I am scraping on quite a few speed humps and driveways, if I don't drive over them on an angle, so not an ideal situation.
    I need to raise the front end of my car up, will raising the front end with different springs or coil overs raise the cross-member section as well?
  14. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Can you get the pipes rerouted?
  15. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    might as well get used to the sound as that is what the supercars will sound like in 2018
  16. Talidorian
    Talidorian Member
    I had it jacked up the other day, just to make sure all the fittings are still tight, there just isn't enough space above to cross-member, if it was just a single system turbo, I would excess space, that extra turbo makes space a premium.
  17. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    Is this also a constant issue with TT V8 Commodores? It's the first that I've heard of it being an issue...
    Perhaps it is a design flaw with the kit?
    If possible, maybe have a look around for some tyres to suit your wheels that have slightly taller side walls, or even strut tower spacers - which would be much cheaper than going down the road of new suspension.
  18. Talidorian
    Talidorian Member
    I'm honestly not sure, having talked to them about it, they get all defensive, so it's really not worth my time to speak to them.
    After doing some research on strut towers spacers I have found that they would only give me body lift, which wouldn't provide any better ground clearance.
    Lift Kits
    A lift kit lifts your entire truck, front and rear, anywhere from a subtle 1” to high enough where you feel the need to duck under overpasses. Lift kits come in two varieties: body lift kits and suspension lift kits.
    A body lift utilizes blocks and spacers to lift the body higher onto the frame of the vehicle without altering any of the suspension geometry. With a body lift kit, your ground clearance remains unchanged, but the extra height allows you to run larger wheels and tires. The steering geometry remains unaltered as well, so your rig retains most of its original driving and handling characteristics. Stability can be negatively impacted, though, due to the increased ride height. Body lifts tend to be more affordable and easier to install than their counterparts – suspension lift kits.
    While the cost may be higher and the installation substantially more involved with a suspension lift, the results are undoubtedly worth it. Suspension lifts typically involve replacing everything from the shocks/struts and leaf springs to the control arms, trailing arms and sometimes even the driveshafts and steering components. Replacing and upgrading these components allows for more suspension articulation, more ground clearance, the ability to run even larger tires, and an all-around more capable off-road vehicle. Stability and driving dynamics can be affected, however, as your truck will now have a higher center of gravity and altered steering and suspension geometry.
    http://www.autoanything.com/suspension-systems/lift-kits-vs-leveling-kits.aspx
    According to the above, a suspension lift would be ideal in my situation.
  19. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    Strut spacers are not the same as a body lift on a full chassis vehicle. I think they would create more underbody clearance.
  20. crew_man
    I would have thought that increasing the distance from strut tower to the hub would have assisted in increasing ride height?
    If nothing else, it would maintain additional clearance under static sag
