2015 VF SS-V Redline Sportwagon - Wheel size query
Discussion in 'VF Holden Commodore (2013 - 2017)' started by wagon37, Jun 30, 2019.
  1. wagon37
    wagon37 Member
    Perth, WA
    2015 VF SS-V Redline Wagon
    I have a 2015 VF SS-V Redline sportwagon with the standard 19" wheels as pictured:
    I want to get new wheels but am confused about the sizing. Are these standard rims 19x8.5 on the front and 19x9.5 on the rear? or 19x8.5 all round?
    I have been told it's illegal to run 9.5 on the back as you need to stagger them?
    I want to fit 19x8.5 all round but not sure if that will work?
    Any help appreciated.
    Cheers.
  2. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    Correct they are staggered stock rims. Same as most GENF HSV being 8.5inch fronts and 9.5inch rears.
    It is not illegal as that is what came as standard. Legally I think it is Ok to run any width, diameter, offset that was an option at manufacture.
    Can anyone comment on if with a stock SS or sv6 were staggered HF20 an option?
  3. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    HF20s are not staggered...
    They are 8.5" wide front and rear
    In your case 8.5" all around is perfectly fine as it was an option from Holden
  4. [paradox]
    [paradox] Active Member
    VF2 SSV-R
    mine are staggered
    RED LION likes this.
  5. Hq King
    Hq King Member
    Taupo NZ
    VF SS 2 Magnum
    Same .I think all 20s are staggered
  6. Forg
    Forg Well-Known Member
    Regal Peackock VF SS-V Redline Wagoon
    Indeed, not all HF20 fitments are staggered - but some were.
    You could get a set of 4 at the same 8.5” width all-round, and you could also get a set at 8.5” front & 9.5” rear.
    If you chose the factory-fitted HF20 option for a 2016 or 2017 Redline, those are staggered.
    But yes, in NSW you can go up to 1” wider than the widest factory-fitted wheels to your model of car. As long as they don’t rub or extend past the wheel-arch, of course. Fortunately for us, the HSV cars are considered “the same”, so you can go 1” wider than the widest that HSV fitted (QLD is the same these days, I thought Victoria was the same but not entirely sure).
  7. Banjo79
    Banjo79 Active Member
    VF SS Sportwagon
    I think your that your rears fitted currently are 19x9. HSV went to 9.5.
    Edit - brain glitch 19x9
    lmoengnr likes this.
  8. abuch47
    Madelaide
    LSS3 YOOTE
    OP has SSVR 19 stock staggered.
    Hf20 can either get staggered or not in gloss black or not staggered in any other finish
  9. 3rspecB
    3rspecB Well-Known Member
    VF2 SSv Redline, White Manual Sedan
    Holden Factory VF Redline 19" staggered rims are 8.5" wide on the front and 9" wide on the rears.
    HSV use 9.5" wide rims on the rears.
  10. abuch47
    Madelaide
    LSS3 YOOTE
    except HSV GENF2 with the widepack wheels (SV forged Rimfires) or GTSR which use 9"front, 10"rear
  11. wagon37
    wagon37 Member
    Perth, WA
    So I'm running 8.5 on the front and 9 on the back?
    Cheers for all the responses so far - much appreciated.
  12. Banjo79
    VF SS Sportwagon
    Yep.
  13. wagon37
    wagon37 Member
    Perth, WA
    Okay thanks for that - 8.5 on the front and 9 on the rear. Got it!
    I'm looking at a set of 19" that are 8.5 all round and with 245 35r 19 tyres.
    Will that set up work okay? or will the rear wheels be well inside the guard because of the smaller width?
    Cheers again.
  14. [paradox]
    VF2 SSV-R
    where they sit in relation to the guard has more to do with offset than the width
  15. abuch47
    Madelaide
    LSS3 YOOTE
    Yeah and generally stock offsets will keep it sitting similarly under the guards ie push it further inwards
  16. wagon37
    wagon37 Member
    Perth, WA
    Ah okay I see - does anyone know what the offsets are on these stock VF SS-V 19" wheels?
    Cheers for all the help - as you can see I have no idea.
  17. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    For an 8.5 it's +48
    For a 9 it's +57
  18. panhead
    NSW Central Coast
    Cars
    The stock 19x8.5 rims come from Holden with 245/40R19 as the OEM tire
    The 19x9 inch rim is fitted with a 275/35R19
  19. Forg
    "Tyre", dagnabbit!
    :p
    Lex likes this.
  20. RWD4ever
    RWD4ever Member
    Gosnells
    VS3 ute
    Would you get oversteer if you don't have the wider tyres at the rear? The Redline has a very thick rear stabiliser bar.
