2006 VZ transmission problem
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by mbannout, May 30, 2018.
  1. mbannout
    mbannout New Member
    Riyadh
    Commodore VZ
    Hello everyone and thank you for this great forum, it has been a great help identifying problems in my car and saving lots of money.
    my car is a 2006 VZ commodore (175kw) and is at it again, my mechanic isn't able to find the problem:
    1- gear is stuck in 3d gear (limp mode)
    2- shifting gears manually works perfectly fine
    3- error code on ODBII is: "P0756 - Powertrain - Shift solenoid "B" performance or stuck off"
    the mechanic took apart and tested both solenoids, both working fine
    4- clearing the codes doesn't do anything, they just come back after 2 minutes
    5- disconnected battery for 15 minutes didn't fix the problem
    my mechanic thinks its the TCM but i feel he's just throwing random guesses at this point.
    please help
  2. shueardm
    shueardm Active Member
    VZ SV6 and VT Olympic Edition Wagon
    You are either not paying him for his time or he should not be your mechanic,
    I think you need to face facts, this is probably going to be a transmission fix that costs a lot of money, maybe even a couple hundred just to diagnose. Go to a transmission specialist is my suggestion.
  3. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    ditto - Consult an Auto Transmission Specialist before throwing any more money at it. Good luck.
  4. Benboy
    Hill River, SA
    2007 SVZ Wagon
  5. Pollushon
    Pollushon Boost gives me a bar....
    VY SS
    If the box shifts fine manually then your fundamentals are okay. Most likely one of two; the PCM is the issue as it controls the solenoid or his test failed to identify a dodgy solenoid. Auto trans specialists will figure this out.
    When the PCM thinks it had a dodgy solenoid it'll go into limp mode
  6. mbannout
    mbannout New Member
    Riyadh
    Commodore VZ
    thanks for all the replies, i took it to 2 transmission specialists and both say it is most probably the Impeller that is damaged, but to be 100% sure they need to take it apart. :( its gonna cost a fortune to fix or replace
  7. lowndes8
    lowndes8 Member
    Radalaide
    VZ SSZ
    Shouldnt cost that much mine cost $1350 to pull apart, replace any worn, rebuild then fit it back into the car
  8. mbannout
    mbannout New Member
    Riyadh
    Commodore VZ
    thanks for all the replies, i took it to 2 transmission specialists and both say it is most probably the Impeller/torque converter that is damaged, but to be 100% sure they need to take it apart. :( its gonna cost a fortune to fix or replace
  9. mbannout
    mbannout New Member
    Riyadh
    Commodore VZ
    :), $1350 is too much given the total value of the car
  10. mbannout
    mbannout New Member
    Riyadh
    Commodore VZ
  11. greenacc
    greenacc Searching for the billion
    VE Berlina
    Value of the car doesn't matter, it's a question of the cars value to you.
    Don't forget the car is worth stuff all of it's not running properly so it will cost you whether you fix it or not.
    Tonner Matt and Lex like this.
  12. ant797
    ant797 Active Member
    bunbury
    vy s
    Im trying to find some ideas for my problem but this forum has become bloated with professional mechanic and people selling parts leading you into exspensive options .i wouldnt of bothered looking on a forum if i was willing or could afford exspensive mechanical services for an old cheap to buy veichle i i would of just taken it to a specialist ..if you no ideas then dont comment
  13. rambunctious
    rambunctious Well-Known Member
    Mooloolaba
    VZ Wagon
    What problem ?
  14. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    If you can't afford to fix a car you can't afford to own a car.
  15. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Professional mechanics are not on this forum in numbers. There are mowing their lawn and going on fishing forums.
    Professional Turf managers and fisherman are on this forum playing with engines.
    Sounds like you need a hug.
  16. ant797
    bunbury
    vy s
    i have 2002 vy ute with tcc solanoid failure error i picked up from a aldl cable 1st time i used it i also got a vss error the engine check warning comes on going 50 km 300m down the road applying brakes and or easing off accelerater ..i have a vss on order and a transmission filter i have already replaced the tps car runs fines accelerates fines accept for sometimes a jolt when coming to a stop
