10psi Pulley (Plugs, coils, leads, thermostat)
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Vy S SC, Aug 24, 2010.
  1. Vy S SC
    Vy S SC New Member
    Wollongong
    VY S Pac Series II Supercharged L67
    Im getting the 10psi pulley upgrade on the weekend. :lock:
    I currently have standard NGK spark plugs, Standard leads (replaced 100kms ago) and stock coils and factory thermostat.
    The car has 160 000kms on the odometer.
    Will i need to upgrade any of the parts mentioned above when I install the 10psi Pulley upgrade?
    Cheers guys :surprise:
  2. wana s' charge stock vt
    wana s' charge stock vt and have :)
    goldcoast
    supercharged vt II acclaim
    get the cooler plugs for sure , and thermo mayb. the l67 coils are fine, they put out the same or more power than the msd coils... one guy used to run 10 sec's of factory coils so think there fine. and standard l67 leads are the most reliable,
    will fine the part numbers for thermo and cooler plugs
  3. wana s' charge stock vt
    goldcoast
    the cooler thermostat part no is- dayco dt22a. got mine from repco $20ish
    the plugs- ngk bpr7efs-15 ,, they come gapped at 1.5mm but need to be regapped to 1.3mm. some people go 1mm gap if have missfiring issues under full boost.. but the bigger the gap the better so try 1.3mm first..
  4. Vy S SC
    Vy S SC New Member
    Wollongong
  5. wana s' charge stock vt
    goldcoast
    just get em from supercheap. $4.50 each , there the same. gapping thems easy.
  6. karlos
    karlos New Member
    VX S S/C & BA XR6T
    If a missfire is felt then yes change some parts.Just make sure you run 98 octane and delete your boost solenoid.L67torque has it all on there.Stay clear of that linked site above also,they(him)operates as FIT Technologies also.Mace,Y/Terra,BYE Perf,TTT Perf and Intense Racing in US will take care of all your needs at better prices.
    If you get a slight missfire then just try regapping your std plugs if serviceable.What charge said above get them from a Autostore.I think the V8 ones are pregapped to 1.3 by memory just go heat range 7 as above said also.Std leads and coils are killa and more than up to task at hand.
  7. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    I think stock plugs will be fine but if you want to go 1 heat range cooler go n ask for NGK BPR7EFS-15. They will need to be re gapped to 1.3mm, no less.
  8. Vy S SC
    Vy S SC New Member
    Wollongong
    so is the 1.5mm stock gap of the plugs too much?
  9. wana s' charge stock vt
    goldcoast
    yeah i think it is. think 1.3 mm is pushing it ..
  10. chargedvx6
    Yes the 1.5mm gap is a tad too much. 1.3mm will be fine
